Introduzione
Your optical headlight units are worn, opaque?
Water is starting to seep in and you can see droplets inside?
This guide will show you how to replace those old headlights units with new ones. Your Yaris will look like it's new!
Cosa ti serve
Unscrew the cross-head screws which attach the front bumper to the car.
Release the plastic clip which attaches the top of the bumper to the middle of the radiator grill.
Disengage the the bumper attachment.
Using a large screwdriver or a small iron bar, lever it as shown until it detaches.
There are 2 attachments to release either side of the bonnet lock.
Completely disengage the bumper from around the headlight, pulling it gently outwards.
Turn the indicator bulb connector a quarter turn counter-clockwise.
Remove the indicator bulb.
Withdraw the rubber boot on the back of the main beam bulb.
Unclip the clip which attaches the main beam bulb and remove the main beam bulb.
Twist the side light connector a quarter towards counter-clockwise.
Withdraw the side light.
Twist headlight dip motor a quarter towards counter-clockwise.
Withdraw the dip motor.
To reassemble your headlight, take care to correctly position the headlight, before reassembling the bulbs, dip motor, and screws.
Make sure the plastic pin on the side of the headlamp is properly inserted into the bodywork.
To reassemble, follow the steps in reverse order.
Altre 4 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
2 Commenti
Merci beaucoup pour ce tuto qui nous a bien servi.
Merci pour le tutoriel qui m'a été d'une grande aide !
Une clé plate peut être utile en absence de cric pour élever le véhicule, car le tournevis risque d’être trop long pour passer sous la voiture.
Sevan KEVORKIAN - Replica
