Salta al contenuto principale
Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement
Cosa ti serve
  1. Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement, Tailgate Handle: passo 1, immagine 1 di 2 Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement, Tailgate Handle: passo 1, immagine 2 di 2
    • Remove the Torx-head screws (23.2mm) on the inside panel of the tailgate, using the torx T25 screwdriver.
  2. Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement: passo 2, immagine 1 di 2 Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement: passo 2, immagine 2 di 2
    • Pull off the panel and then pull cables inward, causing tailgate to release and go down.
  3. Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement: passo 3, immagine 1 di 2 Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement: passo 3, immagine 2 di 2
    • Remove rubber pieces from cable and pull cable from insert.
  4. Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement: passo 4, immagine 1 di 2 Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement: passo 4, immagine 2 di 2
    • Use your 5/16th-in. wrench to turn bolt counter clockwise and remove the bolts (18.5mm).
  5. Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement: passo 5, immagine 1 di 2 Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement: passo 5, immagine 2 di 2
    • Push in black clip to let handle fall out.
  6. Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement: passo 6, immagine 1 di 1
    • Put new tailgate handle back in.
  7. Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement: passo 7, immagine 1 di 1
    • Hand twist in bolts; then tighten with wrench.
  8. Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement: passo 8, immagine 1 di 1
    • Insert cable back into socket and press rubber lock onto cable.
  9. Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement: passo 9, immagine 1 di 1
    • Put panel back into place and screw in using your torx -T25 screwdriver.
Conclusione
This Device is a medium hardness fix but, with hard-work it can be achieved in only about 30 minutes
Brandon Gibson
Membro da: 03/26/20
169 Reputazione
1 Guida realizzata
2 Commenti
You skipped the problematic part about changing the lock.
Declan Haptism - Replica
I’m about to replace my handle.. I also need the 4 white clips that help align the latch rods. Mine were old brittle and all broken. Any chance you have a part number for those small clips?
Ryan Rodriguez - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 11
Ultimi 7 Giorni: 31
Ultimi 30 Giorni: 156
Tutti i Tempi: 10,114
