Salta al contenuto principale
Toyota Corolla 2018 Brake Light Replacement
Cosa ti serve
  1. Toyota Corolla 2018 Brake Light Replacement, Brake Light: passo 1, immagine 1 di 2 Toyota Corolla 2018 Brake Light Replacement, Brake Light: passo 1, immagine 2 di 2
    • Open the trunk lid and remove the two black plastic fasteners on the side of the car with burnt out lights using a flat head screwdriver.
  2. Toyota Corolla 2018 Brake Light Replacement: passo 2, immagine 1 di 2 Toyota Corolla 2018 Brake Light Replacement: passo 2, immagine 2 di 2
    • Pull back the carpet to access the bulbs and locate between the rear turn signal bulb and brake light.
    • The rear turn signal bulb is located at the top and has a grey cap.
    • The brake light is located at the bottom and has an orange cap.
  3. Toyota Corolla 2018 Brake Light Replacement: passo 3, immagine 1 di 2 Toyota Corolla 2018 Brake Light Replacement: passo 3, immagine 2 di 2
    • Turn the brake light counterclockwise and pull the old light straight out of the socket.
  4. Toyota Corolla 2018 Brake Light Replacement: passo 4, immagine 1 di 1
    • Replace the new bulb and push it in the socket.
  5. Toyota Corolla 2018 Brake Light Replacement: passo 5, immagine 1 di 1
    • Turn the socket clockwise while placing it in the housing.
  6. Toyota Corolla 2018 Brake Light Replacement: passo 6, immagine 1 di 2 Toyota Corolla 2018 Brake Light Replacement: passo 6, immagine 2 di 2
    • Push the carpet back in place and screw in the two fasteners to secure the trunk liner.
Linea Traguardo
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 103
Tutti i Tempi: 3,921
