Salta al contenuto principale
Toy Windmill Repair
Cosa ti serve
  1. Toy Windmill Repair, Toy Windmill Repair: passo 1, immagine 1 di 1
    • Use the 120 grit sandpaper to remove any rough edges on both the base unit and any parts which need to be connected to it.
  2. Toy Windmill Repair: passo 2, immagine 1 di 1
    • Use the rough sandpaper on parts that need to be connected to the primary unit as this will result in greater surface contact.
  3. Toy Windmill Repair: passo 3, immagine 1 di 2 Toy Windmill Repair: passo 3, immagine 2 di 2
    • Apply a small amount of wood glue to each end.
    • Connect the two pieces and apply a small amount of masking tape to hold them in place.
  4. Toy Windmill Repair: passo 4, immagine 1 di 1
    • Once all the pieces have been connected and the glue has cured, use the fine sandpaper to smooth out the connected pieces.
  5. Toy Windmill Repair: passo 5, immagine 1 di 1
    • Using the fill stick crayon, blend in the connected pieces.
    • This will require the reader to be creative.
  6. Toy Windmill Repair: passo 6, immagine 1 di 2 Toy Windmill Repair: passo 6, immagine 2 di 2
    • Apply a small amount of wood glue to each end of the windmill.
    • Connect the two pieces and apply a small amount of masking tape to hold the two ends in place.
Conclusione
To reassemble your device, follow these instructions in order.
Karim Ladha
Membro da: 06/27/21
133 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 13
Tutti i Tempi: 320
