Parti
Nessuna parte richiesta.
Make sure the lock switch for the back cover is unlocked.
  • Make sure the lock switch for the back cover is unlocked.
    • The cover is unlocked when the switch is slid in the direction of the 'unlock' icon.
Aggiungi Commento
Remove back cover by prying away from the Thrive.
  • Remove back cover by prying away from the Thrive.
    • The easiest place to pry from is one of the two speakers.
Aggiungi Commento
  • To remove the battery, make sure the lock switch is in the unlocked position.
    • The battery is unlocked when the switch is slid to the unlocked position.
Aggiungi Commento
  • Slide the battery switch release to the right.
    • While holding the switch in place, lift up the battery.
Aggiungi Commento
  • Start by using a screwdriver to remove the 12 screws holding on the back cover. The screws are 5mm in length and require a PH0 screwdriver.
    • All of these screws are identical so don't worry about getting them mixed up.
Aggiungi Commento
  • Start to gently pry the back of the device off, while leaving it loosely in place.
    • Be careful not to tear or damage the cables when removing the back.
Aggiungi Commento
  • Once the back of the case is off, disconnect the wires by gently pulling on the plastic tabs as shown.
Aggiungi Commento
  • Carefully open the device like a book and lay the two halves beside each other.
Can you add a picture of somebody opening the device?
Dan Brown - Replica
  • Separate the two halves of your Thrive
  • Using a Phillips screwdriver, remove the six screws holding the LCD in place. These screws are 3mm in length and require a PH0 screwdriver.
Pictures suddenly get blue here. You could use substitutes, redo these, or fix them with a photo editor.
Dan Brown - Replica
Well I separated the halves but I don't know how to reconnect it. I don't really know how i got it separated.
Sun Fai Lau - Replica
  • With a spudger, disconnect the cable connecting the camera to the motherboard.
Aggiungi Commento
  • Lift up the LCD from the screen and place it on the side
Aggiungi Commento
  • Remove the one screw holding the camera in place. The screw is 3mm in length and requires a PH0 screwdriver.
  • Lift up the camera from the screen.
Aggiungi Commento
Conclusione
Altre 4 persone hanno completato questa guida.
Kason
Membro da: 22/09/2014
945 Reputazione
5 Guide realizzate
USF Tampa, Team 10-1, Brown Fall 2014 Membro di USF Tampa, Team 10-1, Brown Fall 2014
USFT-BROWN-F14S10G1
3 Membri
6 Guide realizzate
Indicate which tools are needed at the top of each guide.
Dan Brown - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 16
Tutti i Tempi: 1,266
