Introduzione
This guide will show you how to replace your front camera.
Cosa ti serve
Make sure the lock switch for the back cover is unlocked.
The cover is unlocked when the switch is slid in the direction of the 'unlock' icon.
Start by using a screwdriver to remove the 12 screws holding on the back cover. The screws are 5mm in length and require a PH0 screwdriver.
All of these screws are identical so don't worry about getting them mixed up.
Separate the two halves of your Thrive
Using a Phillips screwdriver, remove the six screws holding the LCD in place. These screws are 3mm in length and require a PH0 screwdriver.
Well I separated the halves but I don't know how to reconnect it. I don't really know how i got it separated.
