Salta al contenuto principale
Toshiba Tecra Z50-A Speakers Replacement
Cosa ti serve
  1. Toshiba Tecra Z50-A Speakers Replacement, Back Panel: passo 1, immagine 1 di 1
    • Turn off the laptop.
    • Flip the laptop over so the bottom is facing upwards and the hinges are closest to you.
    • Remove the fifteen 5 mm screws from the back panel using a Phillips #0 screwdriver.
  2. Toshiba Tecra Z50-A Speakers Replacement: passo 2, immagine 1 di 1
    • Lift up back panel using your hands and remove it from the rest of the laptop.
  3. Toshiba Tecra Z50-A Speakers Replacement, Battery: passo 3, immagine 1 di 1
    • Lift the plastic covering over the battery plug.
  4. Toshiba Tecra Z50-A Speakers Replacement: passo 4, immagine 1 di 1
    • Pull the wired cable up towards the top of the laptop to disconnect it from its socket on the motherboard.
  5. Toshiba Tecra Z50-A Speakers Replacement: passo 5, immagine 1 di 1
    • Remove the single 2 mm screw from the corner of the laptop using a Phillips #0 screwdriver.
  6. Toshiba Tecra Z50-A Speakers Replacement: passo 6, immagine 1 di 1
    • Remove the three 3 mm screws from the battery using a Phillips #0 screwdriver.
  7. Toshiba Tecra Z50-A Speakers Replacement: passo 7, immagine 1 di 1
    • Lift up on the battery with your hands and remove it from the laptop.
  8. Toshiba Tecra Z50-A Speakers Replacement, Hard Drive: passo 8, immagine 1 di 1
    • Lift up on the hard drive.
  9. Toshiba Tecra Z50-A Speakers Replacement: passo 9, immagine 1 di 2 Toshiba Tecra Z50-A Speakers Replacement: passo 9, immagine 2 di 2
    • Pull out the plug from the hard drive.
  10. Toshiba Tecra Z50-A Speakers Replacement, Speakers: passo 10, immagine 1 di 1
    • Lift up on the tape holding the bundled speaker wire down.
  11. Toshiba Tecra Z50-A Speakers Replacement: passo 11, immagine 1 di 1
    • Pull the bundled wire out of its socket on the motherboard.
  12. Toshiba Tecra Z50-A Speakers Replacement: passo 12, immagine 1 di 3 Toshiba Tecra Z50-A Speakers Replacement: passo 12, immagine 2 di 3 Toshiba Tecra Z50-A Speakers Replacement: passo 12, immagine 3 di 3
    • Lift up on the left speaker with a spudger.
  13. Toshiba Tecra Z50-A Speakers Replacement: passo 13, immagine 1 di 3 Toshiba Tecra Z50-A Speakers Replacement: passo 13, immagine 2 di 3 Toshiba Tecra Z50-A Speakers Replacement: passo 13, immagine 3 di 3
    • Lift up on the right speaker with a spudger and remove both speakers from the laptop.
Conclusione
UMass Dartmouth, Team 2-4, Sinclaire Fall 2021 Membro di UMass Dartmouth, Team 2-4, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S2G4
3 Membri
21 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 19
Tutti i Tempi: 329
