Salta al contenuto principale
Toshiba Tecra 8200 Hard Drive Replacement
Cosa ti serve
  1. Toshiba Tecra 8200 Hard Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Turn off the device and unplug the power cord.
    • To remove the battery, flip the device, so that the bottom is facing upward.
  2. Toshiba Tecra 8200 Hard Drive Replacement: passo 2, immagine 1 di 3 Toshiba Tecra 8200 Hard Drive Replacement: passo 2, immagine 2 di 3 Toshiba Tecra 8200 Hard Drive Replacement: passo 2, immagine 3 di 3
    • Slide the battery to the right side until you hear a click.
    • Carefully remove the battery from its compartment.
  3. Toshiba Tecra 8200 Hard Drive Replacement, Hard Drive: passo 3, immagine 1 di 3 Toshiba Tecra 8200 Hard Drive Replacement, Hard Drive: passo 3, immagine 2 di 3 Toshiba Tecra 8200 Hard Drive Replacement, Hard Drive: passo 3, immagine 3 di 3
    • Locate the hard drive panel.
    • Remove the single screw labeled F4 by using a Philips size #00 screwdriver.
    • Save the screw, as it will be needed for reassembly.
    • Remove the panel, exposing the hard drive.
  4. Toshiba Tecra 8200 Hard Drive Replacement: passo 4, immagine 1 di 2 Toshiba Tecra 8200 Hard Drive Replacement: passo 4, immagine 2 di 2
    • Pull the tab to remove the hard drive.
    • Insert the new hard drive by pushing it into the compartment, leaving the new "pull" tab exposed.
  5. Toshiba Tecra 8200 Hard Drive Replacement: passo 5, immagine 1 di 2 Toshiba Tecra 8200 Hard Drive Replacement: passo 5, immagine 2 di 2
    • Tuck the "pull" tab back into the hard drive compartment.
    • Replace the panel.
    • Replace the single F4 screw.
  6. Toshiba Tecra 8200 Hard Drive Replacement: passo 6, immagine 1 di 3 Toshiba Tecra 8200 Hard Drive Replacement: passo 6, immagine 2 di 3 Toshiba Tecra 8200 Hard Drive Replacement: passo 6, immagine 3 di 3
    • Identify the connector pins on the battery.
    • Line up the connector pins on the battery with the connector pins on the computer and push inward to reconnect the battery.
    • Slide the exterior panel towards the center of the computer to lock the battery in place.
Linea Traguardo
Sally
Membro da: 02/17/15
306 Reputazione
3 Guide realizzate
Ohio State, Team 1-3, Buehl Winter 2015 Membro di Ohio State, Team 1-3, Buehl Winter 2015
OSU-BUEHL-W15S1G3
3 Membri
9 Guide realizzate
Un commento
Awesome Thanks!
Erin Dulac - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 14
Tutti i Tempi: 2,336
