Salta al contenuto principale
Toshiba TY-LP 200 Belt Replacement
Cosa ti serve
  1. Toshiba TY-LP 200 Belt Replacement, Belt: passo 1, immagine 1 di 2 Toshiba TY-LP 200 Belt Replacement, Belt: passo 1, immagine 2 di 2
    • Unplug the turntable and remove the dust cover by lifting the lid horizontally.
  2. Toshiba TY-LP 200 Belt Replacement: passo 2, immagine 1 di 2 Toshiba TY-LP 200 Belt Replacement: passo 2, immagine 2 di 2
    • Locate the C-clip at the center base of the platter and remove it with a flathead screwdriver.
  3. Toshiba TY-LP 200 Belt Replacement: passo 3, immagine 1 di 2 Toshiba TY-LP 200 Belt Replacement: passo 3, immagine 2 di 2
    • Once removed, very gently lift the platter straight up and off the device.
    • Flip the platter upside down.
  4. Toshiba TY-LP 200 Belt Replacement: passo 4, immagine 1 di 3 Toshiba TY-LP 200 Belt Replacement: passo 4, immagine 2 di 3 Toshiba TY-LP 200 Belt Replacement: passo 4, immagine 3 di 3
    • Place the new belt around the center ring of the upside-down platter.
    • After placing the new belt, stretch the belt towards one of the indented areas on the back of the platter.
  5. Toshiba TY-LP 200 Belt Replacement: passo 5, immagine 1 di 1
    • Locate the spool drive that is surrounded by three screws.
  6. Toshiba TY-LP 200 Belt Replacement: passo 6, immagine 1 di 1
    • Once you have located the spool drive, place the stretched belt over it, and gently put back the platter into its original form, as shown in step 2.
    • If this step is done correctly, once the platter is spun, it will stop by itself.
  7. Toshiba TY-LP 200 Belt Replacement: passo 7, immagine 1 di 2 Toshiba TY-LP 200 Belt Replacement: passo 7, immagine 2 di 2
    • Place the C-type back into its original place and, with your finger, attach it onto the spindle.
    • Reinstall the dust cover by placing it on the snaps and applying force downwards.
Conclusione
You now have a fixed and working record player.
Andrew
Membro da: 05/14/20
145 Reputazione
1 Guida realizzata
3 Commenti
Thank you so much for this! Incredibly helpful!!!
Judi Dell'Anno - Replica
Replacement belt size?
lyam_pa - Replica
Along with this fix, I tried to clean a bit of dust and grime that's accumulated throughout the 3 decades. Some is not coming off with vacuuming or dry-wiping. Any advice on how to clean the unit up before reassembly? Mine is a gold Marantz with similar design and some of its parts are not as smooth as they should be. Thanks so much
Edie K - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 16
Tutti i Tempi: 1,235
