Salta al contenuto principale
Toshiba TECRA R940 Back Panel Replacement
Cosa ti serve
  1. Toshiba TECRA R940 Back Panel Replacement, Battery: passo 1, immagine 1 di 2 Toshiba TECRA R940 Back Panel Replacement, Battery: passo 1, immagine 2 di 2
    • Slide lock 1, located on the right side, to the unlocked position.
  2. Toshiba TECRA R940 Back Panel Replacement: passo 2, immagine 1 di 2 Toshiba TECRA R940 Back Panel Replacement: passo 2, immagine 2 di 2
    • While holding lock 2 (left side) in the unlocked position, pull out the battery pack.
    • It is not necessary to hold open lock 2 for re-installation.
  3. Toshiba TECRA R940 Back Panel Replacement, Back Panel: passo 3, immagine 1 di 2 Toshiba TECRA R940 Back Panel Replacement, Back Panel: passo 3, immagine 2 di 2
    • Unscrew the single screw on the RAM access panel using a Phillips #0 screwdriver.
    • The screw will not come apart from the panel.
    • Use a plastic opening tool to pry off the access panel.
  4. Toshiba TECRA R940 Back Panel Replacement: passo 4, immagine 1 di 2 Toshiba TECRA R940 Back Panel Replacement: passo 4, immagine 2 di 2
    • Remove the 11 mm screw from the right side of the hard drive access panel using a Phillips #0 screwdriver.
    • Remove the 3.5 mm screw from the left side of the access panel using a Phillips #0 screwdriver.
    • Use a plastic opening tool to pry off the access panel from the bottom.
  5. Toshiba TECRA R940 Back Panel Replacement: passo 5, immagine 1 di 1
    • Remove twelve 5.5 mm screws from the main back cover using a Phillips #0 screwdriver.
    • Remove three 11 mm screws from main back cover and mini access panel using a Phillips #0 screwdriver.
    • Remove two 9.5 mm screws from the main back cover using a Phillips #0 screwdriver.
  6. Toshiba TECRA R940 Back Panel Replacement: passo 6, immagine 1 di 2 Toshiba TECRA R940 Back Panel Replacement: passo 6, immagine 2 di 2
    • Lift the hard drive out of the access panel.
    • Disconnect the SATA connector from the hard drive by pulling straight out.
  7. Toshiba TECRA R940 Back Panel Replacement: passo 7, immagine 1 di 2 Toshiba TECRA R940 Back Panel Replacement: passo 7, immagine 2 di 2
    • Insert the plastic opening tool into the edge of the laptop and pry off the back cover.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 17
Tutti i Tempi: 990
