Salta al contenuto principale
Introduzione
The bulb of a projector is only rated for a certain amount of hours, so when it reaches the end of its life the image will become fuzzy and eventually die out. This guide will show how to replace the bulb on this projector.
Ricambi
  1. Remove the two screws from the bottom plate as shown. Remove the two screws from the bottom plate as shown.
    • Remove the two screws from the bottom plate as shown.
  2. Remove the two screws on the bulb housing.
    • Remove the two screws on the bulb housing.
  3. Pull the tab up and pull the bulb out vertically. Some force will be required, but it will come out. Replace the bulb with an equivalent one.
    • Pull the tab up and pull the bulb out vertically. Some force will be required, but it will come out.
    • Replace the bulb with an equivalent one.
Conclusione
Bryan Underwood
Membro da: 02/04/2018
697 Reputazione
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 183
