Salta al contenuto principale
Toshiba Satellite c650d RAM Replacement
Cosa ti serve
  1. Toshiba Satellite c650d RAM Replacement, Battery: passo 1, immagine 1 di 1
    • Unplug the laptop and turn it off.
    • Flip the laptop upside down.
    • Locate the battery on the underside of the laptop.
  2. Toshiba Satellite c650d RAM Replacement: passo 2, immagine 1 di 1
    • Push the two latches away from the battery.
  3. Toshiba Satellite c650d RAM Replacement: passo 3, immagine 1 di 2 Toshiba Satellite c650d RAM Replacement: passo 3, immagine 2 di 2
    • Slide the battery away from the laptop.
    • Locate the serial number on the battery to order a replacement.
  4. Toshiba Satellite c650d RAM Replacement, RAM: passo 4, immagine 1 di 1
    • Remove the one 5.5mm Philips #0 screw that holds in the central panel.
  5. Toshiba Satellite c650d RAM Replacement: passo 5, immagine 1 di 1
    • Pull the back panel off.
  6. Toshiba Satellite c650d RAM Replacement: passo 6, immagine 1 di 1
    • Remove the RAM.
    • Carefully undo the clips on either side of the top RAM.
    • Remove the chip by pulling it out of its slot.
    • Repeat until you have removed the chip that you want to replace.
    • This laptop has only two slots for RAM, and both are filled. Plan accordingly if your goal is to increase RAM.
Conclusione
UMass Dartmouth, Team 5-2, Gulbrandsen Fall 2015 Membro di UMass Dartmouth, Team 5-2, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G2
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 707
