Toshiba Satellite U925T-S2120 Fan Replacement
Introduzione
Vai al passo 1In this guide you will learn how to remove the fan of your Toshiba Satellite U925T-S2120. If your fan is broken, you may need to replace it. Before beginning this guide you should have all required tools that are listed.
Cosa ti serve
Attrezzo utilizzato in questo passaggio:Tweezers$4.99
Use tweezers to remove the 9 rubber grip pads on the back panel of the laptop.
