Salta al contenuto principale
Toshiba Satellite U405D-S2902 RAM Replacement
Cosa ti serve
  1. Toshiba Satellite U405D-S2902 RAM Replacement, RAM: passo 1, immagine 1 di 2 Toshiba Satellite U405D-S2902 RAM Replacement, RAM: passo 1, immagine 2 di 2
    • Lay the device face down with the battery facing away from you. Locate the center panel. It will have two vents in it and three screws on the left side.
    • Loosen the three screws that hold the rear access panel on, using your Phillips #1 Screwdriver.
    • The screws will not actually come out from the panel but will be loose and let the panel come off.
    • Lift the left side of the panel to remove it.
  2. Toshiba Satellite U405D-S2902 RAM Replacement: passo 2, immagine 1 di 1
    • Locate and pull back the two mounting clips on either side of the memory chip.
    • Be sure that when replacing the board, push down gently until the clips snap back in.
  3. Toshiba Satellite U405D-S2902 RAM Replacement: passo 3, immagine 1 di 2 Toshiba Satellite U405D-S2902 RAM Replacement: passo 3, immagine 2 di 2
    • Lift RAM circuit board to about a 45 degree angle and pull gently to the right.
Conclusione
That's it for hardware, the remaining steps will depend on the software platform being run on your laptop.
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 7-8, Maness Winter 2013 Membro di Cal Poly, Team 7-8, Maness Winter 2013
CPSU-MANESS-W13S7G8
4 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 14
Tutti i Tempi: 616
