Salta al contenuto principale
Toshiba Satellite U405D-S2902 Keyboard Replacement
Cosa ti serve
  1. Toshiba Satellite U405D-S2902 Keyboard Replacement, Keyboard: passo 1, immagine 1 di 3 Toshiba Satellite U405D-S2902 Keyboard Replacement, Keyboard: passo 1, immagine 2 di 3 Toshiba Satellite U405D-S2902 Keyboard Replacement, Keyboard: passo 1, immagine 3 di 3
    • Situate the laptop so that it is open and the display is facing you.
    • Use the plastic opening tool to pry the black plastic insert upward. The insert can be found at the top of the keyboard.
    • Once the insert is loose, carefully remove it from the device.
  2. Toshiba Satellite U405D-S2902 Keyboard Replacement: passo 2, immagine 1 di 2 Toshiba Satellite U405D-S2902 Keyboard Replacement: passo 2, immagine 2 di 2
    • Using #1 Phillips Screwdriver, remove both of the 5 mm screws that are located beneath the insert.
  3. Toshiba Satellite U405D-S2902 Keyboard Replacement: passo 3, immagine 1 di 2 Toshiba Satellite U405D-S2902 Keyboard Replacement: passo 3, immagine 2 di 2
    • Use the plastic opening tool to begin removing the keys off of the device.
    • Once the keys are off, gently remove the keyboard. Be careful of the ribbon cable that still connects the keyboard to motherboard.
  4. Toshiba Satellite U405D-S2902 Keyboard Replacement: passo 4, immagine 1 di 2 Toshiba Satellite U405D-S2902 Keyboard Replacement: passo 4, immagine 2 di 2
    • Lift up the gate on the ZIF socket to release the ribbon.
    • Ease the ribbon connecting the keyboard to the motherboard out of the ZIF socket.
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 7-8, Maness Winter 2013 Membro di Cal Poly, Team 7-8, Maness Winter 2013
CPSU-MANESS-W13S7G8
4 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 630
