Introduzione
The function of the keyboard is to allow you to type on the computer. Sometimes it can break and need to be replaced.
Strumenti
Parti
Nessuna parte specificata.
Situate the laptop so that it is open and the display is facing you.
Use the plastic opening tool to pry the black plastic insert upward. The insert can be found at the top of the keyboard.
Once the insert is loose, carefully remove it from the device.
Altre 2 persone hanno completato questa guida.
