Salta al contenuto principale
Introduzione
The battery on the Satellite is relatively small and after a year or so it may no longer hold a full charge. Replacing the battery will allow you to retain the full functional life.
  1. Make sure that the laptop is off and unplugged.
    • Make sure that the laptop is off and unplugged.
    • Turn the laptop over.
    • Slide back the left lock, and you should hear a click when it is successfully locked back in.
  2. Rotate the laptop 180 degrees so that the battery is near you.
    • Rotate the laptop 180 degrees so that the battery is near you.
    • Hold back the spring slide and pull the battery out.
Conclusione
Altre 2 persone hanno completato questa guida.
Brandon Kirklen
Membro da: 11/01/2013
269 Reputazione
8 Guide realizzate
Cal Poly, Team 7-8, Maness Winter 2013 Membro di Cal Poly, Team 7-8, Maness Winter 2013
CPSU-MANESS-W13S7G8
4 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 398
