Salta al contenuto principale
Toshiba Satellite S75D-A7346 RAM Replacement
Cosa ti serve
  1. Toshiba Satellite S75D-A7346 RAM Replacement, Taking Out The Battery: passo 1, immagine 1 di 2 Toshiba Satellite S75D-A7346 RAM Replacement, Taking Out The Battery: passo 1, immagine 2 di 2
    • First we have to take out the battery
    • Pull the switch on the left to the left
    • then hold the switch on the right to the right direction
    • then pull up the bttery from the point inbetween the 2 switches
  2. Toshiba Satellite S75D-A7346 RAM Replacement, UnScrewing The BackPlate: passo 2, immagine 1 di 2 Toshiba Satellite S75D-A7346 RAM Replacement, UnScrewing The BackPlate: passo 2, immagine 2 di 2
    • Unscrew the screw located next to the information sticker
    • Then get a screw driver or prier to gently pry the covering plate
  3. Toshiba Satellite S75D-A7346 RAM Replacement, Taking Out The RAM Sticks: passo 3, immagine 1 di 2 Toshiba Satellite S75D-A7346 RAM Replacement, Taking Out The RAM Sticks: passo 3, immagine 2 di 2
    • Gently move the 2 notches on the ends of each ram stick and the stick should pop out at a 30 degree angle
    • then pull that ram stick out
    • you can do the same to the other one
  4. Toshiba Satellite S75D-A7346 RAM Replacement, Adding In New RAM Sticks: passo 4, immagine 1 di 2 Toshiba Satellite S75D-A7346 RAM Replacement, Adding In New RAM Sticks: passo 4, immagine 2 di 2
    • Insert the lowest ram stick first by inserting it at a 30 degree angle then push down on it
    • Note: do not put a lot of pressure on it
    • Note: make sure before you push it down the RAM stick is all the way in
    • Note: The maximum supported RAM is 8 GB in each slot of DDR3 1600Mhz
  5. Toshiba Satellite S75D-A7346 RAM Replacement, Putting On The Backplate: passo 5, immagine 1 di 2 Toshiba Satellite S75D-A7346 RAM Replacement, Putting On The Backplate: passo 5, immagine 2 di 2
    • Put on the backplate and put pressure arround the edges of the blackplate so it stays flat with the case
    • Then screw in the screw next to the information sticker
  6. Toshiba Satellite S75D-A7346 RAM Replacement, Putting In The Battery: passo 6, immagine 1 di 3 Toshiba Satellite S75D-A7346 RAM Replacement, Putting In The Battery: passo 6, immagine 2 di 3 Toshiba Satellite S75D-A7346 RAM Replacement, Putting In The Battery: passo 6, immagine 3 di 3
    • Place the battery in the slot
    • Then hold the right switch to the right and push the battery in, then release the switch.
    • move the left switch to the right
  7. Toshiba Satellite S75D-A7346 RAM Replacement, You Finished: passo 7, immagine 1 di 1
    • You have know finished the replacement
Linea Traguardo
Emil Lambert
Membro da: 12/16/16
228 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 209
