Salta al contenuto principale
Toshiba Satellite S55t-C5225 Speakers Replacement
Cosa ti serve
  1. Toshiba Satellite S55t-C5225 Speakers Replacement, Battery: passo 1, immagine 1 di 1
    • Shut down the computer and disconnect all cables
    • Flip the computer over so the bottom is facing up.
  2. Toshiba Satellite S55t-C5225 Speakers Replacement: passo 2, immagine 1 di 2 Toshiba Satellite S55t-C5225 Speakers Replacement: passo 2, immagine 2 di 2
    • Remove the two 7.0 mm Phillips #0 screws that hold the battery in place.
  3. Toshiba Satellite S55t-C5225 Speakers Replacement: passo 3, immagine 1 di 2 Toshiba Satellite S55t-C5225 Speakers Replacement: passo 3, immagine 2 di 2
    • Carefully remove the battery by wedging a plastic opening tool in-between the battery and back cover.
  4. Toshiba Satellite S55t-C5225 Speakers Replacement, Back Panel: passo 4, immagine 1 di 2 Toshiba Satellite S55t-C5225 Speakers Replacement, Back Panel: passo 4, immagine 2 di 2
    • Remove the eleven 7.0 mm Phillips #0 screws that secure the back cover.
  5. Toshiba Satellite S55t-C5225 Speakers Replacement: passo 5, immagine 1 di 2 Toshiba Satellite S55t-C5225 Speakers Replacement: passo 5, immagine 2 di 2
    • Wedge the tip of a plastic opening tool between the back cover and metal frame.
    • Twist the plastic tool, while wedged, to release the retaining tabs from the frame.
    • Repeat these steps around the laptop to release all retaining tabs.
  6. Toshiba Satellite S55t-C5225 Speakers Replacement: passo 6, immagine 1 di 2 Toshiba Satellite S55t-C5225 Speakers Replacement: passo 6, immagine 2 di 2
    • Once all retaining tabs are released, pull up on the cover to remove.
  7. Toshiba Satellite S55t-C5225 Speakers Replacement, Speakers: passo 7, immagine 1 di 1
    • Disconnect the power button strip by flipping up the white plastic clamp that connects it to the motherboard.
    • Pull the ribbon wire out from plastic clamp.
  8. Toshiba Satellite S55t-C5225 Speakers Replacement: passo 8, immagine 1 di 2 Toshiba Satellite S55t-C5225 Speakers Replacement: passo 8, immagine 2 di 2
    • Remove the four 10.0 mm Phillips #0 screws that hold the speakers in place.
  9. Toshiba Satellite S55t-C5225 Speakers Replacement: passo 9, immagine 1 di 2 Toshiba Satellite S55t-C5225 Speakers Replacement: passo 9, immagine 2 di 2
    • Follow the black wire that connects the speakers to the motherboard.
    • Pull the wire out from its socket to disconnect the speakers from the motherboard.
  10. Toshiba Satellite S55t-C5225 Speakers Replacement: passo 10, immagine 1 di 2 Toshiba Satellite S55t-C5225 Speakers Replacement: passo 10, immagine 2 di 2
    • Lift speakers up from their mounted position to remove.
Conclusione
Ali Mortada
Membro da: 10/21/19
217 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 38
Tutti i Tempi: 895
