Salta al contenuto principale
Toshiba Satellite S55t-C5225 Screen Assembly Replacement
Cosa ti serve
  1. Toshiba Satellite S55t-C5225 Screen Assembly Replacement, Battery: passo 1, immagine 1 di 1
    • Shut down the computer and disconnect all cables
    • Flip the computer over so the bottom is facing up.
  2. Toshiba Satellite S55t-C5225 Screen Assembly Replacement: passo 2, immagine 1 di 2 Toshiba Satellite S55t-C5225 Screen Assembly Replacement: passo 2, immagine 2 di 2
    • Remove the two 7.0 mm Phillips #0 screws that hold the battery in place.
  3. Toshiba Satellite S55t-C5225 Screen Assembly Replacement: passo 3, immagine 1 di 2 Toshiba Satellite S55t-C5225 Screen Assembly Replacement: passo 3, immagine 2 di 2
    • Carefully remove the battery by wedging a plastic opening tool in-between the battery and back cover.
  4. Toshiba Satellite S55t-C5225 Screen Assembly Replacement, Back Panel: passo 4, immagine 1 di 2 Toshiba Satellite S55t-C5225 Screen Assembly Replacement, Back Panel: passo 4, immagine 2 di 2
    • Remove the eleven 7.0 mm Phillips #0 screws that secure the back cover.
  5. Toshiba Satellite S55t-C5225 Screen Assembly Replacement: passo 5, immagine 1 di 2 Toshiba Satellite S55t-C5225 Screen Assembly Replacement: passo 5, immagine 2 di 2
    • Wedge the tip of a plastic opening tool between the back cover and metal frame.
    • Twist the plastic tool, while wedged, to release the retaining tabs from the frame.
    • Repeat these steps around the laptop to release all retaining tabs.
  6. Toshiba Satellite S55t-C5225 Screen Assembly Replacement: passo 6, immagine 1 di 2 Toshiba Satellite S55t-C5225 Screen Assembly Replacement: passo 6, immagine 2 di 2
    • Once all retaining tabs are released, pull up on the cover to remove.
  7. Toshiba Satellite S55t-C5225 Screen Assembly Replacement, Speakers: passo 7, immagine 1 di 1
    • Disconnect the power button strip by flipping up the white plastic clamp that connects it to the motherboard.
    • Pull the ribbon wire out from plastic clamp.
  8. Toshiba Satellite S55t-C5225 Screen Assembly Replacement: passo 8, immagine 1 di 2 Toshiba Satellite S55t-C5225 Screen Assembly Replacement: passo 8, immagine 2 di 2
    • Remove the four 10.0 mm Phillips #0 screws that hold the speakers in place.
  9. Toshiba Satellite S55t-C5225 Screen Assembly Replacement: passo 9, immagine 1 di 2 Toshiba Satellite S55t-C5225 Screen Assembly Replacement: passo 9, immagine 2 di 2
    • Follow the black wire that connects the speakers to the motherboard.
    • Pull the wire out from its socket to disconnect the speakers from the motherboard.
  10. Toshiba Satellite S55t-C5225 Screen Assembly Replacement: passo 10, immagine 1 di 2 Toshiba Satellite S55t-C5225 Screen Assembly Replacement: passo 10, immagine 2 di 2
    • Lift speakers up from their mounted position to remove.
  11. Toshiba Satellite S55t-C5225 Screen Assembly Replacement, Screen Assembly: passo 11, immagine 1 di 2 Toshiba Satellite S55t-C5225 Screen Assembly Replacement, Screen Assembly: passo 11, immagine 2 di 2
    • Disconnect LAN from the motherboard power wire. Pop up the white clamp that holds it in place, then pull the wire out.
  12. Toshiba Satellite S55t-C5225 Screen Assembly Replacement: passo 12, immagine 1 di 2 Toshiba Satellite S55t-C5225 Screen Assembly Replacement: passo 12, immagine 2 di 2
    • Disconnect the two cables connecting the screen assembly to the WIFI card.
  13. Toshiba Satellite S55t-C5225 Screen Assembly Replacement: passo 13, immagine 1 di 3 Toshiba Satellite S55t-C5225 Screen Assembly Replacement: passo 13, immagine 2 di 3 Toshiba Satellite S55t-C5225 Screen Assembly Replacement: passo 13, immagine 3 di 3
    • Disconnect all remaining cables that connect the screen assembly to the motherboard.
  14. Toshiba Satellite S55t-C5225 Screen Assembly Replacement: passo 14, immagine 1 di 1
  15. Toshiba Satellite S55t-C5225 Screen Assembly Replacement: passo 15, immagine 1 di 2 Toshiba Satellite S55t-C5225 Screen Assembly Replacement: passo 15, immagine 2 di 2
    • Remove the four 7.0 mm Phillips #0 screws on both ends of the laptop that attach the screen assembly to the laptop.
  16. Toshiba Satellite S55t-C5225 Screen Assembly Replacement: passo 16, immagine 1 di 3 Toshiba Satellite S55t-C5225 Screen Assembly Replacement: passo 16, immagine 2 di 3 Toshiba Satellite S55t-C5225 Screen Assembly Replacement: passo 16, immagine 3 di 3
    • Slowly open laptop while the bottom is facing up. Begin to separate the bottom of laptop from the screen assembly brackets.
    • Remove the screen assembly.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 17
Tutti i Tempi: 961
