Salta al contenuto principale
Toshiba Satellite S55t-C5225 RAM Replacement
Cosa ti serve
  1. Toshiba Satellite S55t-C5225 RAM Replacement, Battery: passo 1, immagine 1 di 1
    • Shut down the computer and disconnect all cables
    • Flip the computer over so the bottom is facing up.
  2. Toshiba Satellite S55t-C5225 RAM Replacement: passo 2, immagine 1 di 2 Toshiba Satellite S55t-C5225 RAM Replacement: passo 2, immagine 2 di 2
    • Remove the two 7.0 mm Phillips #0 screws that hold the battery in place.
  3. Toshiba Satellite S55t-C5225 RAM Replacement: passo 3, immagine 1 di 2 Toshiba Satellite S55t-C5225 RAM Replacement: passo 3, immagine 2 di 2
    • Carefully remove the battery by wedging a plastic opening tool in-between the battery and back cover.
  4. Toshiba Satellite S55t-C5225 RAM Replacement, Back Panel: passo 4, immagine 1 di 2 Toshiba Satellite S55t-C5225 RAM Replacement, Back Panel: passo 4, immagine 2 di 2
    • Remove the eleven 7.0 mm Phillips #0 screws that secure the back cover.
  5. Toshiba Satellite S55t-C5225 RAM Replacement: passo 5, immagine 1 di 2 Toshiba Satellite S55t-C5225 RAM Replacement: passo 5, immagine 2 di 2
    • Wedge the tip of a plastic opening tool between the back cover and metal frame.
    • Twist the plastic tool, while wedged, to release the retaining tabs from the frame.
    • Repeat these steps around the laptop to release all retaining tabs.
  6. Toshiba Satellite S55t-C5225 RAM Replacement: passo 6, immagine 1 di 2 Toshiba Satellite S55t-C5225 RAM Replacement: passo 6, immagine 2 di 2
    • Once all retaining tabs are released, pull up on the cover to remove.
  7. Toshiba Satellite S55t-C5225 RAM Replacement, RAM: passo 7, immagine 1 di 3 Toshiba Satellite S55t-C5225 RAM Replacement, RAM: passo 7, immagine 2 di 3 Toshiba Satellite S55t-C5225 RAM Replacement, RAM: passo 7, immagine 3 di 3
    • Press on the metals clips on the outside of the RAM to release it.
    • Gently pull out the first RAM stick. Repeat the process for the other RAM stick.
Conclusione
Altre 3 persone hanno completato questa guida.
Un commento
Est ce que on remplacer une ram de 4 par une autre de 8
Sadek - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 13
Tutti i Tempi: 504
