Salta al contenuto principale
Toshiba Satellite S55t-C5225 Optical Disk Drive Replacement
Cosa ti serve
  1. Toshiba Satellite S55t-C5225 Optical Disk Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Shut down the computer and disconnect all cables
    • Flip the computer over so the bottom is facing up.
  2. Toshiba Satellite S55t-C5225 Optical Disk Drive Replacement: passo 2, immagine 1 di 2 Toshiba Satellite S55t-C5225 Optical Disk Drive Replacement: passo 2, immagine 2 di 2
    • Remove the two 7.0 mm Phillips #0 screws that hold the battery in place.
  3. Toshiba Satellite S55t-C5225 Optical Disk Drive Replacement: passo 3, immagine 1 di 2 Toshiba Satellite S55t-C5225 Optical Disk Drive Replacement: passo 3, immagine 2 di 2
    • Carefully remove the battery by wedging a plastic opening tool in-between the battery and back cover.
  4. Toshiba Satellite S55t-C5225 Optical Disk Drive Replacement, Back Panel: passo 4, immagine 1 di 2 Toshiba Satellite S55t-C5225 Optical Disk Drive Replacement, Back Panel: passo 4, immagine 2 di 2
    • Remove the eleven 7.0 mm Phillips #0 screws that secure the back cover.
  5. Toshiba Satellite S55t-C5225 Optical Disk Drive Replacement: passo 5, immagine 1 di 2 Toshiba Satellite S55t-C5225 Optical Disk Drive Replacement: passo 5, immagine 2 di 2
    • Wedge the tip of a plastic opening tool between the back cover and metal frame.
    • Twist the plastic tool, while wedged, to release the retaining tabs from the frame.
    • Repeat these steps around the laptop to release all retaining tabs.
  6. Toshiba Satellite S55t-C5225 Optical Disk Drive Replacement: passo 6, immagine 1 di 2 Toshiba Satellite S55t-C5225 Optical Disk Drive Replacement: passo 6, immagine 2 di 2
    • Once all retaining tabs are released, pull up on the cover to remove.
  7. Toshiba Satellite S55t-C5225 Optical Disk Drive Replacement, Optical Disk Drive: passo 7, immagine 1 di 2 Toshiba Satellite S55t-C5225 Optical Disk Drive Replacement, Optical Disk Drive: passo 7, immagine 2 di 2
    • Carefully slide the optical disk drive to the right to remove from the motherboard.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 11
Tutti i Tempi: 323
