Salta al contenuto principale
Toshiba Satellite S55t-A5389 Processor Replacement
Cosa ti serve
  1. Toshiba Satellite S55t-A5389 Processor Replacement, Battery: passo 1, immagine 1 di 1
    • Remove the fourteen 5mm Phillips #0 screws from the bottom of the laptop.
  2. Toshiba Satellite S55t-A5389 Processor Replacement: passo 2, immagine 1 di 1
    • Using the plastic prying tools, go around the edge of the bottom of the laptop to release the cover.
  3. Toshiba Satellite S55t-A5389 Processor Replacement: passo 3, immagine 1 di 3 Toshiba Satellite S55t-A5389 Processor Replacement: passo 3, immagine 2 di 3 Toshiba Satellite S55t-A5389 Processor Replacement: passo 3, immagine 3 di 3
    • Remove the four 5mm Phillips #0 screws from the battery.
    • Unplug the battery from the motherboard.
    • Remove the battery from the laptop.
  4. Toshiba Satellite S55t-A5389 Processor Replacement, Processor Fan: passo 4, immagine 1 di 1
    • Remove the two 5mm Phillips #0 screws from the fan.
  5. Toshiba Satellite S55t-A5389 Processor Replacement: passo 5, immagine 1 di 1
    • Disconnect the fan from the motherboard.
  6. Toshiba Satellite S55t-A5389 Processor Replacement: passo 6, immagine 1 di 1
    • Remove the four 5mm Phillips #0 screws from the heat pipe.
    • Remove the fan and heat pipe from the laptop.
  7. Toshiba Satellite S55t-A5389 Processor Replacement, Processor: passo 7, immagine 1 di 1
    • Rotate the lock 90 degrees using a Torx T8 in order to remove the processor.
  8. Toshiba Satellite S55t-A5389 Processor Replacement: passo 8, immagine 1 di 1
    • Carefully lift up the processor.
    • When putting the new processor on, make sure that the little arrow on the processor matches with the arrow on the socket
Conclusione
Altre 2 persone hanno completato questa guida.
USF Tampa, Team S5-G6, Passmore Spring 2018 Membro di USF Tampa, Team S5-G6, Passmore Spring 2018
USFT-PASSMORE-S18S5G6
3 Membri
8 Guide realizzate
Un commento
Can i use i7 4940mx cpu on this laptop
Movies Star - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 633
