Salta al contenuto principale
Toshiba Satellite S55t-A5389 Keyboard Replacement
Cosa ti serve
  1. Toshiba Satellite S55t-A5389 Keyboard Replacement, Keyboard: passo 1, immagine 1 di 1
    • Flip laptop over so that the bottom is facing upwards.
    • Remove the two 5mm Phillips #0 screws from the bottom of the laptop.
  2. Toshiba Satellite S55t-A5389 Keyboard Replacement: passo 2, immagine 1 di 2 Toshiba Satellite S55t-A5389 Keyboard Replacement: passo 2, immagine 2 di 2
    • Flip the laptop over and open the display.
    • Insert a plastic opening tool into the gap found between the keyboard and top case.
    • Pry upwards until you hear a click and work your way around the perimeter of the keyboard.
  3. Toshiba Satellite S55t-A5389 Keyboard Replacement: passo 3, immagine 1 di 3 Toshiba Satellite S55t-A5389 Keyboard Replacement: passo 3, immagine 2 di 3 Toshiba Satellite S55t-A5389 Keyboard Replacement: passo 3, immagine 3 di 3
    • Lift the keyboard up, but not all the way since there's a ribbon cable attached underneath.
    • Underneath the keyboard is a ribbon cable that attaches it to the rest of the laptop.
    • Unlock the ribbon cable by lifting up the two small locks on both sides of the connector on the motherboard.
    • Once unlocked, remove the ribbon cable and keyboard from the laptop.
Conclusione
Altre 3 persone hanno completato questa guida.
USF Tampa, Team S5-G6, Passmore Spring 2018 Membro di USF Tampa, Team S5-G6, Passmore Spring 2018
USFT-PASSMORE-S18S5G6
3 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 633
