Salta al contenuto principale
Toshiba Satellite S55T-B5335 Wi-Fi Adapter Replacement
Cosa ti serve
  1. Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement, Battery: passo 1, immagine 1 di 1
    • Remove the two 7 mm Phillips #1 screws that hold the battery in place.
  2. Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement: passo 2, immagine 1 di 3 Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement: passo 2, immagine 2 di 3 Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement: passo 2, immagine 3 di 3
    • Pull the battery from laptop.
  3. Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement, Bottom Cover: passo 3, immagine 1 di 2 Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement, Bottom Cover: passo 3, immagine 2 di 2
    • Remove the ten 7 mm Phillips #1 screws that secure the back cover.
  4. Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement: passo 4, immagine 1 di 1
    • Wedge the tip of a plastic opening tool between the back cover and the metal frame.
    • Twist the plastic opening tool, while wedged, in order to release the retaining tabs from the frame.
    • Repeat these steps in a circular pattern around the laptop to release all retaining tabs.
  5. Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement: passo 5, immagine 1 di 1
    • Once all retaining tabs are released from the frame, you can pull up on the back cover to remove it.
  6. Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement, Wi-Fi Adapter: passo 6, immagine 1 di 1
    • Using the pointed end of the Spudger, gently disconnect the antenna (white and black wires) from the Wi-Fi adapter.
  7. Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement: passo 7, immagine 1 di 1
    • Remove the single 4 mm Phillips #1 screw holding the Wi-Fi adapter in place.
  8. Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement: passo 8, immagine 1 di 1
    • While grabbing the Wi-Fi adapter on both sides, gently pull away from the socket in the direction of the removed screw.
Conclusione
USF Tampa, Team 2-1, Blackwell Fall 2016 Membro di USF Tampa, Team 2-1, Blackwell Fall 2016
USFT-BLACKWELL-F16S2G1
4 Membri
7 Guide realizzate
Un commento
George, do you know where the graphics chip is at on that motherboard?
Any Where - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,257
