Salta al contenuto principale
Toshiba Satellite S50-B Cooling Fan Replacement
Cosa ti serve
  1. Toshiba Satellite S50-B Cooling Fan Replacement, Battery: passo 1, immagine 1 di 2 Toshiba Satellite S50-B Cooling Fan Replacement, Battery: passo 1, immagine 2 di 2
    • Make sure you turn off the laptop first.
    • Unscrew the two 6.5mm screws below the battery using a Phillips #0 Screwdriver.
  2. Toshiba Satellite S50-B Cooling Fan Replacement: passo 2, immagine 1 di 2 Toshiba Satellite S50-B Cooling Fan Replacement: passo 2, immagine 2 di 2
    • Place thumbs on corners of the battery. Pinch the battery between the thumb and index finger and pull.
  3. Toshiba Satellite S50-B Cooling Fan Replacement, Cooling Fan: passo 3, immagine 1 di 3 Toshiba Satellite S50-B Cooling Fan Replacement, Cooling Fan: passo 3, immagine 2 di 3 Toshiba Satellite S50-B Cooling Fan Replacement, Cooling Fan: passo 3, immagine 3 di 3
    • Locate the 10 screws on the bottom of the device, there should be 12 screws in total including the battery screws. Unscrew using a Phillips #0 screwdriver, and set screws aside.
    • Use a plastic opening tool to remove the bottom panel.
  4. Toshiba Satellite S50-B Cooling Fan Replacement: passo 4, immagine 1 di 3 Toshiba Satellite S50-B Cooling Fan Replacement: passo 4, immagine 2 di 3 Toshiba Satellite S50-B Cooling Fan Replacement: passo 4, immagine 3 di 3
    • Locate the 2 screws on each fan. Unscrew them.
    • Disconnect the fan by applying gentle pressure to the circled connection with your finger and pulling.
    • Remove the fans. Be sure to keep track of the right and left fans, marked R and L.
Conclusione
diana calvo
Membro da: 10/17/17
144 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 8
Tutti i Tempi: 1,533
