Salta al contenuto principale
Toshiba Satellite Radius P55W-B5220 USB/SD/headphone jack Replacement
Cosa ti serve
  1. Toshiba Satellite Radius P55W-B5220 USB/SD/headphone jack Replacement, Back Cover: passo 1, immagine 1 di 1
    • Turn off the laptop before starting.
    • Remove the two rubber feet closest to the hinge with a plastic opening tool.
  2. Toshiba Satellite Radius P55W-B5220 USB/SD/headphone jack Replacement: passo 2, immagine 1 di 1
    • Remove the twelve M2x4mm PH0 Philips head screws.
  3. Toshiba Satellite Radius P55W-B5220 USB/SD/headphone jack Replacement: passo 3, immagine 1 di 1
    • Loosen the back cover with a plastic opening tool.
    • The least damaging way to pry the cover is to start from a corner and run the spudger along the edge.
    • Do not crack or bend the cover.
  4. Toshiba Satellite Radius P55W-B5220 USB/SD/headphone jack Replacement: passo 4, immagine 1 di 1
    • Carefully lift open the cover.
    • Remove the attached purple ribbon cable underneath the cover.
    • Do not rip the ribbon cable.
  5. Toshiba Satellite Radius P55W-B5220 USB/SD/headphone jack Replacement, USB/SD/headphone jack: passo 5, immagine 1 di 1
    • Unscrew the two screws holding the panel of the UBS/SD card/headphone jack
  6. Toshiba Satellite Radius P55W-B5220 USB/SD/headphone jack Replacement: passo 6, immagine 1 di 1
    • disconnect the cable shown from the motherboard
  7. Toshiba Satellite Radius P55W-B5220 USB/SD/headphone jack Replacement: passo 7, immagine 1 di 1
    • disconnect the cable attached to the top of the USB/SD card/headphone jack interface
  8. Toshiba Satellite Radius P55W-B5220 USB/SD/headphone jack Replacement: passo 8, immagine 1 di 1
    • remove the interface
Conclusione
Garrett barta
Membro da: 09/20/17
101 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 409
