Salta al contenuto principale
Toshiba Satellite Radius P55W-B5220 RAM Replacement
Cosa ti serve
  1. Toshiba Satellite Radius P55W-B5220 RAM Replacement, Back Cover: passo 1, immagine 1 di 1
    • Turn off the laptop before starting.
    • Remove the two rubber feet closest to the hinge with a plastic opening tool.
  2. Toshiba Satellite Radius P55W-B5220 RAM Replacement: passo 2, immagine 1 di 1
    • Remove the twelve M2x4mm PH0 Philips head screws.
  3. Toshiba Satellite Radius P55W-B5220 RAM Replacement: passo 3, immagine 1 di 1
    • Loosen the back cover with a plastic opening tool.
    • The least damaging way to pry the cover is to start from a corner and run the spudger along the edge.
    • Do not crack or bend the cover.
  4. Toshiba Satellite Radius P55W-B5220 RAM Replacement: passo 4, immagine 1 di 1
    • Carefully lift open the cover.
    • Remove the attached purple ribbon cable underneath the cover.
    • Do not rip the ribbon cable.
  5. Toshiba Satellite Radius P55W-B5220 RAM Replacement, RAM: passo 5, immagine 1 di 2 Toshiba Satellite Radius P55W-B5220 RAM Replacement, RAM: passo 5, immagine 2 di 2
    • Push outward on the clamps holding the RAM in place.
  6. Toshiba Satellite Radius P55W-B5220 RAM Replacement: passo 6, immagine 1 di 1
    • Remove the RAM chips.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 678
