Salta al contenuto principale
Toshiba Satellite Radius P55W-B5220 Hard Drive Replacement
Cosa ti serve
  1. Toshiba Satellite Radius P55W-B5220 Hard Drive Replacement, Hard Drive: passo 1, immagine 1 di 1
    • Turn off the laptop before starting
    • Remove the two rubber feet closest to the hinge with a plastic opening tool
  2. Toshiba Satellite Radius P55W-B5220 Hard Drive Replacement: passo 2, immagine 1 di 1
    • Remove the twelve M2x4mm PH0 Philips head screws.
  3. Toshiba Satellite Radius P55W-B5220 Hard Drive Replacement: passo 3, immagine 1 di 1
    • Loosen the back cover with a opening tool.
    • The least damaging way to pry the cover is to start from corner and run the spudger along the edge.
    • Do not crack or bend the cover.
  4. Toshiba Satellite Radius P55W-B5220 Hard Drive Replacement: passo 4, immagine 1 di 1
    • Carefully lift open the cover.
    • Remove the attached purple ribbon cable underneath the cover.
    • Do not rip the ribbon cable.
  5. Toshiba Satellite Radius P55W-B5220 Hard Drive Replacement: passo 5, immagine 1 di 1
    • Gently lift up the hard drive
  6. Toshiba Satellite Radius P55W-B5220 Hard Drive Replacement: passo 6, immagine 1 di 1
    • Gently lift up the black tab attached to the strip
Conclusione
Altre 6 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,639
