Salta al contenuto principale
Toshiba Satellite P855-S5312 Keyboard Replacement
Cosa ti serve
  1. Toshiba Satellite P855-S5312 Keyboard Replacement, Battery: passo 1, immagine 1 di 3 Toshiba Satellite P855-S5312 Keyboard Replacement, Battery: passo 1, immagine 2 di 3 Toshiba Satellite P855-S5312 Keyboard Replacement, Battery: passo 1, immagine 3 di 3
    • Turn laptop upside down with the spine facing towards you and locate the two tabs on the top of the back panel.
    • Move the sliders to the left and right to release the tabs holding the battery in.
    • While the tabs are pushed outwards, remove the battery from the device.
  2. Toshiba Satellite P855-S5312 Keyboard Replacement, Keyboard: passo 2, immagine 1 di 3 Toshiba Satellite P855-S5312 Keyboard Replacement, Keyboard: passo 2, immagine 2 di 3 Toshiba Satellite P855-S5312 Keyboard Replacement, Keyboard: passo 2, immagine 3 di 3
    • Using plastic spudger to pry up the edges of the keyboard and lift it towards the screen.
    • Unplug the ZIF connector ribbon using the plastic spudger by gently prying the edges of the plug.
    • Remove the keyboard from the device.
Conclusione
To reassemble your device, plug the ribbon into circuit board and snap the replacement keyboard in place.
Dalton
Membro da: 10/02/17
215 Reputazione
2 Guide realizzate
USF Tampa, Team S10-G2, Thompson Fall 2017 Membro di USF Tampa, Team S10-G2, Thompson Fall 2017
USFT-THOMPSON-F17S10G2
3 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 1,252
