Introduzione
This Guide is to help replace the fan for theToshiba Satellite P855-S5312. Replacing the fan in the device will resolve overheating issues caused by inadequate cooling. Tools required for the guide are plastic opening tool and Phillips size 0 screwdriver.
Cosa ti serve
Turn laptop upside down with the spine facing towards you and locate the two tabs on the top of the back panel.
Move the sliders to the left and right to release the tabs holding the battery in.
While the tabs are pushed outwards, remove the battery from the device.
Using plastic spudger to pry up the edges of the keyboard and lift it towards the screen.
Unplug the ZIF connector ribbon using the plastic spudger by gently prying the edges of the plug.
Remove the keyboard from the device.
Unscrew the one 1.5mm screw using a Philips #0 screwdriver holding the L shape panel.
Pry up the panel to gain access to hidden screws.
