Salta al contenuto principale
Toshiba Satellite P855-S5312 Fan Replacement
Cosa ti serve
  1. Toshiba Satellite P855-S5312 Fan Replacement, Battery: passo 1, immagine 1 di 3 Toshiba Satellite P855-S5312 Fan Replacement, Battery: passo 1, immagine 2 di 3 Toshiba Satellite P855-S5312 Fan Replacement, Battery: passo 1, immagine 3 di 3
    • Turn laptop upside down with the spine facing towards you and locate the two tabs on the top of the back panel.
    • Move the sliders to the left and right to release the tabs holding the battery in.
    • While the tabs are pushed outwards, remove the battery from the device.
  2. Toshiba Satellite P855-S5312 Fan Replacement, Keyboard: passo 2, immagine 1 di 3 Toshiba Satellite P855-S5312 Fan Replacement, Keyboard: passo 2, immagine 2 di 3 Toshiba Satellite P855-S5312 Fan Replacement, Keyboard: passo 2, immagine 3 di 3
    • Using plastic spudger to pry up the edges of the keyboard and lift it towards the screen.
    • Unplug the ZIF connector ribbon using the plastic spudger by gently prying the edges of the plug.
    • Remove the keyboard from the device.
  3. Toshiba Satellite P855-S5312 Fan Replacement, Fan: passo 3, immagine 1 di 3 Toshiba Satellite P855-S5312 Fan Replacement, Fan: passo 3, immagine 2 di 3 Toshiba Satellite P855-S5312 Fan Replacement, Fan: passo 3, immagine 3 di 3
    • Unscrew the one 1.5mm screw using a Philips #0 screwdriver holding the L shape panel.
    • Pry up the panel to gain access to hidden screws.
  4. Toshiba Satellite P855-S5312 Fan Replacement: passo 4, immagine 1 di 2 Toshiba Satellite P855-S5312 Fan Replacement: passo 4, immagine 2 di 2
    • Remove the fourteen (14) screws using a Philips #0 screwdriver for the 1.5mm screws on the underside of casing.
  5. Toshiba Satellite P855-S5312 Fan Replacement: passo 5, immagine 1 di 3 Toshiba Satellite P855-S5312 Fan Replacement: passo 5, immagine 2 di 3 Toshiba Satellite P855-S5312 Fan Replacement: passo 5, immagine 3 di 3
    • Unscrew the nine 1.5mm screws using a Philips #0 screwdriver under the keyboard with the F6 printed next to them.
    • Unplug the three no-fuss ribbon cable connector cables by gently pulling on them away from you towards the keyboard.
  6. Toshiba Satellite P855-S5312 Fan Replacement: passo 6, immagine 1 di 2 Toshiba Satellite P855-S5312 Fan Replacement: passo 6, immagine 2 di 2
    • Pry apart the casing with the plastic opening tool.
    • Removing the cover under keyboard.
  7. Toshiba Satellite P855-S5312 Fan Replacement: passo 7, immagine 1 di 3 Toshiba Satellite P855-S5312 Fan Replacement: passo 7, immagine 2 di 3 Toshiba Satellite P855-S5312 Fan Replacement: passo 7, immagine 3 di 3
    • Unplug the single no-fuss cable connector using the plastic opening tool pushing the edges towards the fan.
    • Unscrew the two 1.5mm screws using a Philips #0 screwdriver by the head mounting holding down the fan.
    • Pull the fan up and remove it from the device.
Conclusione
Dalton
Membro da: 10/02/17
215 Reputazione
2 Guide realizzate
USF Tampa, Team S10-G2, Thompson Fall 2017 Membro di USF Tampa, Team S10-G2, Thompson Fall 2017
USFT-THOMPSON-F17S10G2
3 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 13
Tutti i Tempi: 558
