Salta al contenuto principale
Toshiba Satellite P55t-A5116 RAM Replacement
Cosa ti serve
  1. Toshiba Satellite P55t-A5116 RAM  Replacement, Back Casing: passo 1, immagine 1 di 2 Toshiba Satellite P55t-A5116 RAM  Replacement, Back Casing: passo 1, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Close laptop and turn it upside down
    • Remove the 14 circular rubber covers with tweezers along with one smaller more cylindrical rubber cover.
  2. Toshiba Satellite P55t-A5116 RAM  Replacement: passo 2, immagine 1 di 2 Toshiba Satellite P55t-A5116 RAM  Replacement: passo 2, immagine 2 di 2
    • Using the #PH0 screw head, remove 14 (5.7 mm) screws from the back casing.
  3. Toshiba Satellite P55t-A5116 RAM  Replacement: passo 3, immagine 1 di 3 Toshiba Satellite P55t-A5116 RAM  Replacement: passo 3, immagine 2 di 3 Toshiba Satellite P55t-A5116 RAM  Replacement: passo 3, immagine 3 di 3
    • Gently pry off the bottom case with the plastic opening tools.
    • Find the seam between the back case and the rest of the laptop casing.
  4. Toshiba Satellite P55t-A5116 RAM  Replacement, RAM: passo 4, immagine 1 di 3 Toshiba Satellite P55t-A5116 RAM  Replacement, RAM: passo 4, immagine 2 di 3 Toshiba Satellite P55t-A5116 RAM  Replacement, RAM: passo 4, immagine 3 di 3
    • Locate the RAM cover on the back of the Laptop.
    • Using the #PH0 screw head, remove 1 (5.7mm) screw.
    • Use the plastic opening tool to remove the RAM cover.
  5. Toshiba Satellite P55t-A5116 RAM  Replacement: passo 5, immagine 1 di 3 Toshiba Satellite P55t-A5116 RAM  Replacement: passo 5, immagine 2 di 3 Toshiba Satellite P55t-A5116 RAM  Replacement: passo 5, immagine 3 di 3
    • Pull out the latches on either side.
    • The RAM should pop up.
    • Remove the RAM.
    • Repeat for other side.
Conclusione
Un commento
I’m confused… it only seems like Step 4 and Step 5 are necessary. Does the battery need to be removed before replacing the RAM? If that’s why Steps 1-3 are there, there’s a lot of steps/information missing. It just goes from “take off the bottom case” to “remove the RAM cover of intact laptop”.
Douggy - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 590
