Introduzione
Use this guide to remove the Toshiba Satellite P55t-A5116 Fan CPU cooler.
Cosa ti serve
Attrezzo utilizzato in questo passaggio:Tweezers$4.99
Close laptop and turn it upside down
Remove the 14 circular rubber covers with tweezers along with one smaller more cylindrical rubber cover.
Use the #PH0 screw head, remove 4 (5.7mm) screws.
Unplug the battery's 10 pin connector and gently lift the battery out of the laptop.
Using a PH0 screwdriver, remove 2 (5.7mm) screws.
Using a PH0 screwdriver, remove 4 (3.68mm) screws.
Altre 3 persone hanno completato questa guida.
