Salta al contenuto principale
Toshiba Satellite P55t-A5116 Battery Replacement
Cosa ti serve
  1. Toshiba Satellite P55t-A5116 Battery Replacement, Back Casing: passo 1, immagine 1 di 2 Toshiba Satellite P55t-A5116 Battery Replacement, Back Casing: passo 1, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Close laptop and turn it upside down
    • Remove the 14 circular rubber covers with tweezers along with one smaller more cylindrical rubber cover.
  2. Toshiba Satellite P55t-A5116 Battery Replacement: passo 2, immagine 1 di 2 Toshiba Satellite P55t-A5116 Battery Replacement: passo 2, immagine 2 di 2
    • Using the #PH0 screw head, remove 14 (5.7 mm) screws from the back casing.
  3. Toshiba Satellite P55t-A5116 Battery Replacement: passo 3, immagine 1 di 3 Toshiba Satellite P55t-A5116 Battery Replacement: passo 3, immagine 2 di 3 Toshiba Satellite P55t-A5116 Battery Replacement: passo 3, immagine 3 di 3
    • Gently pry off the bottom case with the plastic opening tools.
    • Find the seam between the back case and the rest of the laptop casing.
  4. Toshiba Satellite P55t-A5116 Battery Replacement, Battery: passo 4, immagine 1 di 2 Toshiba Satellite P55t-A5116 Battery Replacement, Battery: passo 4, immagine 2 di 2
    • Use the #PH0 screw head, remove 4 (5.7mm) screws.
    • Unplug the battery's 10 pin connector and gently lift the battery out of the laptop.
  5. Toshiba Satellite P55t-A5116 Battery Replacement: passo 5, immagine 1 di 1
    • Gently remove battery from the laptop.
Conclusione
Altre 12 persone hanno completato questa guida.
9 Commenti
The screws for the battery are in very tight and I'm having trouble unscrewing them
Brianna Brucale - Replica
I'm having difficulty unplugging the 10 pin connector. Afraid if I pull too hard it will pull the wires out. Any suggestions?
jmomenee - Replica
Just wiggle it back-and-forth a bit and it should come out. I just change my own battery.
Carmen Cuevas -
I did all of that but my laptop didn’t reboot, any suggestions
roberta - Replica
I had no problem installing the new battery, but even after letting it charge over 24 hours. Not able to get it to turn on
roberta - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 24
Tutti i Tempi: 22,776
