Salta al contenuto principale
Toshiba Satellite P55W-C5316 Screen Replacement
Cosa ti serve
  1. Toshiba Satellite P55W-C5316 Screen Replacement, Back Panel: passo 1, immagine 1 di 2 Toshiba Satellite P55W-C5316 Screen Replacement, Back Panel: passo 1, immagine 2 di 2
    • To prevent injury, ensure the laptop is powered off before starting your work.
    • Unscrew the .3mm Phillips head screws on the back panel using the PH1 screwdriver.
  2. Toshiba Satellite P55W-C5316 Screen Replacement: passo 2, immagine 1 di 3 Toshiba Satellite P55W-C5316 Screen Replacement: passo 2, immagine 2 di 3 Toshiba Satellite P55W-C5316 Screen Replacement: passo 2, immagine 3 di 3
    • Be careful to not crack the panel where the USB and power cord ports are.
    • Insert the opening tool in between the back panel and the laptop to pry it open.
    • The back panel is magnetically attached at the front of the laptop so you may have to move the opening tool along the length of the panel.
    • Lift the panel from the front off of the laptop.
  3. Toshiba Satellite P55W-C5316 Screen Replacement, Fan: passo 3, immagine 1 di 1
    • Remove both screws from the fan.
  4. Toshiba Satellite P55W-C5316 Screen Replacement: passo 4, immagine 1 di 2 Toshiba Satellite P55W-C5316 Screen Replacement: passo 4, immagine 2 di 2
    • Remove the screws securing the 4 corners of the heatsink.
    • Gently remove the heatsink. Keep in mind thermal paste is used and it may be slightly difficult to remove.
  5. Toshiba Satellite P55W-C5316 Screen Replacement: passo 5, immagine 1 di 3 Toshiba Satellite P55W-C5316 Screen Replacement: passo 5, immagine 2 di 3 Toshiba Satellite P55W-C5316 Screen Replacement: passo 5, immagine 3 di 3
    • Remove the small, beige colored connector securing the fan to the laptop and remove the fan and heatsink assembly from the laptop.
  6. Toshiba Satellite P55W-C5316 Screen Replacement, Screen: passo 6, immagine 1 di 2 Toshiba Satellite P55W-C5316 Screen Replacement, Screen: passo 6, immagine 2 di 2
    • Using the Phillips #00 screwdriver, remove the two screws securing the silver USB protector located on the far right side of the laptop, and pry off the protector.
    • Remove the three screws at the top end of the USB protector using the Phillips #00 screwdriver.
  7. Toshiba Satellite P55W-C5316 Screen Replacement: passo 7, immagine 1 di 1
    • Using the Phillips #0 screwdriver, remove the screws on metal hinge securing the screen to the laptop.
    • There was only a single screw at the time of guide creation but you should remove any screws from the hinge.
  8. Toshiba Satellite P55W-C5316 Screen Replacement: passo 8, immagine 1 di 1
    • Repeat the previous step to remove the screws on the other hinge securing the display to the device.
  9. Toshiba Satellite P55W-C5316 Screen Replacement: passo 9, immagine 1 di 2 Toshiba Satellite P55W-C5316 Screen Replacement: passo 9, immagine 2 di 2
    • Remove all of the black tape securing the hinge to the laptop.
  10. Toshiba Satellite P55W-C5316 Screen Replacement: passo 10, immagine 1 di 1
    • Disconnect the connector directly above the IO cable.
  11. Toshiba Satellite P55W-C5316 Screen Replacement: passo 11, immagine 1 di 1
    • Remove the display assembly from the device.
Conclusione
Kyle Dierking
Membro da: 11/07/19
133 Reputazione
1 Guida realizzata
IUPUI, Team S2-G1, Harley Fall 2019 Membro di IUPUI, Team S2-G1, Harley Fall 2019
IUPUI-HARLEY-F19S2G1
3 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 19
Tutti i Tempi: 662
