Introduzione
The fan in a laptop keeps the device cool and from overheating. If your Toshiba Satellite P55W-C5316 starts to overheat, other components in your device may start to fail. In addition, you may experience that your device is running slower than normal. If your device is overheating and if your fan is making loud noises, it is time to replace the fan in your device. Follow these instructions to remove the fan from your Toshiba Satellite P55W-C5316 laptop.
Cosa ti serve
Unscrew the .3mm Phillips head screws on the back panel using the PH1 screwdriver.
