Introduzione
This guide about removing the battery is fairly straightforward. Be careful to not yank on the connector between the battery and the laptop. Also, make sure that the laptop is turned off before attempting this guide.
Strumenti
Unscrew the .3mm Phillips head screws on the back panel using the PH1 screwdriver.
The battery is located in the bottom right corner of the laptop.
Remove the four .5mm Phillips head screws on the battery using the PH1 screwdriver.
Altre 2 persone hanno completato questa guida.
