Salta al contenuto principale
Toshiba Satellite P55W-C5316 Back Panel Replacement
Cosa ti serve
  1. Toshiba Satellite P55W-C5316 Back Panel Replacement, Back Panel: passo 1, immagine 1 di 2 Toshiba Satellite P55W-C5316 Back Panel Replacement, Back Panel: passo 1, immagine 2 di 2
    • To prevent injury, ensure the laptop is powered off before starting your work.
    • Unscrew the .3mm Phillips head screws on the back panel using the PH1 screwdriver.
  2. Toshiba Satellite P55W-C5316 Back Panel Replacement: passo 2, immagine 1 di 3 Toshiba Satellite P55W-C5316 Back Panel Replacement: passo 2, immagine 2 di 3 Toshiba Satellite P55W-C5316 Back Panel Replacement: passo 2, immagine 3 di 3
    • Be careful to not crack the panel where the USB and power cord ports are.
    • Insert the opening tool in between the back panel and the laptop to pry it open.
    • The back panel is magnetically attached at the front of the laptop so you may have to move the opening tool along the length of the panel.
    • Lift the panel from the front off of the laptop.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 1,014
