Salta al contenuto principale
Toshiba Satellite P55W-C5200X RAM Replacement
Cosa ti serve
  1. Toshiba Satellite P55W-C5200X RAM Replacement, Battery: passo 1, immagine 1 di 3 Toshiba Satellite P55W-C5200X RAM Replacement, Battery: passo 1, immagine 2 di 3 Toshiba Satellite P55W-C5200X RAM Replacement, Battery: passo 1, immagine 3 di 3
    • Use the Phillips #00 screwdriver to remove the ten 4.0 mm screws located at the bottom of the laptop.
  2. Toshiba Satellite P55W-C5200X RAM Replacement: passo 2, immagine 1 di 1
    • Use the black nylon spudger to pry the back casing along the edges.
    • Continue to pry along the edge of the back case until the back is ready to be removed.
  3. Toshiba Satellite P55W-C5200X RAM Replacement: passo 3, immagine 1 di 2 Toshiba Satellite P55W-C5200X RAM Replacement: passo 3, immagine 2 di 2
    • Remove the four 6.0 mm screws that hold the battery in place using the JIS #000 screwdriver.
  4. Toshiba Satellite P55W-C5200X RAM Replacement: passo 4, immagine 1 di 2 Toshiba Satellite P55W-C5200X RAM Replacement: passo 4, immagine 2 di 2
    • Disconnect the battery cable from the motherboard by carefully pulling on the black wire at the point closest to the white tab.
  5. Toshiba Satellite P55W-C5200X RAM Replacement: passo 5, immagine 1 di 2 Toshiba Satellite P55W-C5200X RAM Replacement: passo 5, immagine 2 di 2
    • Gently remove the battery from your device.
  6. Toshiba Satellite P55W-C5200X RAM Replacement, RAM: passo 6, immagine 1 di 3 Toshiba Satellite P55W-C5200X RAM Replacement, RAM: passo 6, immagine 2 di 3 Toshiba Satellite P55W-C5200X RAM Replacement, RAM: passo 6, immagine 3 di 3
    • For this particular model of the device there will be two sticks of RAM.
    • There are two metal brackets holding each RAM stick in place. Carefully move the metal brackets outward on both sides at the same time.
    • Pull the RAM sticks out.
Conclusione
Hadi Termos
Membro da: 10/21/19
241 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 12
Tutti i Tempi: 934
