Introduzione
Is your Toshiba Satellite P55W-C5200X making weird noises or getting to very high temperatures? If so a problem may be occurring with your fan. One cause may be something may be caught or blocking the fan, or dust could be collecting on your fan. It could be a more severe reason as well being a defective fan that should be replaced immediately.
The recommendation would be to check and see, and see if a replacement is in order. There is not much risk involved in doing so but it is advised to make sure the device is turned off and the battery is removed when working on its components.
All tools needed to check and /or replace the fan unit are listed below.
This guide will show Toshiba Satellite P55W-C5200X users how to replace a defective fan.
Cosa ti serve
Use the Phillips #00 screwdriver to remove the ten 4.0 mm screws located at the bottom of the laptop.
Remove the two 4.0 mm screws using the Phillips #00 screwdriver.
Remove the four 2.0 mm screws using the Phillips #0 screwdriver.
