Salta al contenuto principale
Toshiba Satellite P55W-C5200X Display Replacement
Cosa ti serve
  1. Toshiba Satellite P55W-C5200X Display Replacement, Battery: passo 1, immagine 1 di 3 Toshiba Satellite P55W-C5200X Display Replacement, Battery: passo 1, immagine 2 di 3 Toshiba Satellite P55W-C5200X Display Replacement, Battery: passo 1, immagine 3 di 3
    • Use the Phillips #00 screwdriver to remove the ten 4.0 mm screws located at the bottom of the laptop.
  2. Toshiba Satellite P55W-C5200X Display Replacement: passo 2, immagine 1 di 1
    • Use the black nylon spudger to pry the back casing along the edges.
    • Continue to pry along the edge of the back case until the back is ready to be removed.
  3. Toshiba Satellite P55W-C5200X Display Replacement: passo 3, immagine 1 di 2 Toshiba Satellite P55W-C5200X Display Replacement: passo 3, immagine 2 di 2
    • Remove the four 6.0 mm screws that hold the battery in place using the JIS #000 screwdriver.
  4. Toshiba Satellite P55W-C5200X Display Replacement: passo 4, immagine 1 di 2 Toshiba Satellite P55W-C5200X Display Replacement: passo 4, immagine 2 di 2
    • Disconnect the battery cable from the motherboard by carefully pulling on the black wire at the point closest to the white tab.
  5. Toshiba Satellite P55W-C5200X Display Replacement: passo 5, immagine 1 di 2 Toshiba Satellite P55W-C5200X Display Replacement: passo 5, immagine 2 di 2
    • Gently remove the battery from your device.
  6. Toshiba Satellite P55W-C5200X Display Replacement, Display: passo 6, immagine 1 di 3 Toshiba Satellite P55W-C5200X Display Replacement, Display: passo 6, immagine 2 di 3 Toshiba Satellite P55W-C5200X Display Replacement, Display: passo 6, immagine 3 di 3
    • Use the Phillips #00 screwdriver to remove the six 5.0 mm screws that are holding the metal brackets on both sides in place.
    • Gently remove both metal brackets.
  7. Toshiba Satellite P55W-C5200X Display Replacement: passo 7, immagine 1 di 3 Toshiba Satellite P55W-C5200X Display Replacement: passo 7, immagine 2 di 3 Toshiba Satellite P55W-C5200X Display Replacement: passo 7, immagine 3 di 3
    • Remove he three wires connected to the motherboard.
  8. Toshiba Satellite P55W-C5200X Display Replacement: passo 8, immagine 1 di 3 Toshiba Satellite P55W-C5200X Display Replacement: passo 8, immagine 2 di 3 Toshiba Satellite P55W-C5200X Display Replacement: passo 8, immagine 3 di 3
    • On the other side remove the four remaining wires from their ports.
  9. Toshiba Satellite P55W-C5200X Display Replacement: passo 9, immagine 1 di 3 Toshiba Satellite P55W-C5200X Display Replacement: passo 9, immagine 2 di 3 Toshiba Satellite P55W-C5200X Display Replacement: passo 9, immagine 3 di 3
    • Lift two sets of metal brackets up, one in each corner.
    • Depending on the force needed on your specific device, you may need to use the spudger.
  10. Toshiba Satellite P55W-C5200X Display Replacement: passo 10, immagine 1 di 2 Toshiba Satellite P55W-C5200X Display Replacement: passo 10, immagine 2 di 2
    • Gently lift the device away from the display assembly.
    • Be aware of the wires attached to the screen so they don't snag on anything.
Conclusione
Hadi Termos
Membro da: 10/21/19
241 Reputazione
2 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 20
Tutti i Tempi: 1,083
