Salta al contenuto principale
Toshiba Satellite P50W-C Mother Board Replacement
Cosa ti serve
  1. Toshiba Satellite P50W-C Mother Board Replacement, Back Cover: passo 1, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Turn the laptop off, unplug the AC adapter, and any other auxiliary components.
    • Turn over the laptop and proceed to take out the seven 5mm silver JIS #1 head screws. If some of the screws are difficult to take out use the tweezers to help.
  2. Toshiba Satellite P50W-C Mother Board Replacement: passo 2, immagine 1 di 1
    • Use the screwdriver to take out the three 5mm black JIS #1 head screws that are located on the hinge.
  3. Toshiba Satellite P50W-C Mother Board Replacement: passo 3, immagine 1 di 2 Toshiba Satellite P50W-C Mother Board Replacement: passo 3, immagine 2 di 2
    • Use the spudger to pry under the back cover until it pops off.
  4. Toshiba Satellite P50W-C Mother Board Replacement, Mother Board: passo 4, immagine 1 di 3 Toshiba Satellite P50W-C Mother Board Replacement, Mother Board: passo 4, immagine 2 di 3 Toshiba Satellite P50W-C Mother Board Replacement, Mother Board: passo 4, immagine 3 di 3
    • Remove all power connections to the motherboard. Including the black and white power connections to the wifi module.
  5. Toshiba Satellite P50W-C Mother Board Replacement: passo 5, immagine 1 di 3 Toshiba Satellite P50W-C Mother Board Replacement: passo 5, immagine 2 di 3 Toshiba Satellite P50W-C Mother Board Replacement: passo 5, immagine 3 di 3
    • Unscrew the two 7 mm JIS head screws in the fan .
    • Then unscrew the four 2 mm JIS head screws connecting the heat sink to the mother board.
    • Then take out the heat sink and fan.
  6. Toshiba Satellite P50W-C Mother Board Replacement: passo 6, immagine 1 di 1
    • Remove both 3mm JIS head screws connecting the motherboard to the device.
  7. Toshiba Satellite P50W-C Mother Board Replacement: passo 7, immagine 1 di 1
    • Remove 5mm silver Phillips head screw connecting black cover to the motherboard
  8. Toshiba Satellite P50W-C Mother Board Replacement: passo 8, immagine 1 di 2 Toshiba Satellite P50W-C Mother Board Replacement: passo 8, immagine 2 di 2
    • Remove all three 5 mm silver JIS head screws connecting the silver cover to the motherboard.
  9. Toshiba Satellite P50W-C Mother Board Replacement: passo 9, immagine 1 di 1
    • You can now gently remove the motherboard from the device.
Conclusione
Brittany Edwards
Membro da: 09/25/17
104 Reputazione
1 Guida realizzata
USF Tampa, Team S3-G2, Cannon Fall 2017 Membro di USF Tampa, Team S3-G2, Cannon Fall 2017
USFT-CANNON-F17S3G2
4 Membri
7 Guide realizzate
Un commento
Hi dear,
My laptop bios was crashed,
I need to radius 15 p50w-c-104 bios dump file.
can you help me please.?
labexperiance@gmail.com
thank you
Mustafa SAYIN - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 509
