Salta al contenuto principale
Toshiba Satellite P50W-C Hard Drive Replacement
Cosa ti serve
  1. Toshiba Satellite P50W-C Hard Drive Replacement, Back Cover: passo 1, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Turn the laptop off, unplug the AC adapter, and any other auxiliary components.
    • Turn over the laptop and proceed to take out the seven 5mm silver JIS #1 head screws. If some of the screws are difficult to take out use the tweezers to help.
  2. Toshiba Satellite P50W-C Hard Drive Replacement: passo 2, immagine 1 di 1
    • Use the screwdriver to take out the three 5mm black JIS #1 head screws that are located on the hinge.
  3. Toshiba Satellite P50W-C Hard Drive Replacement: passo 3, immagine 1 di 2 Toshiba Satellite P50W-C Hard Drive Replacement: passo 3, immagine 2 di 2
    • Use the spudger to pry under the back cover until it pops off.
  4. Toshiba Satellite P50W-C Hard Drive Replacement, Hard Drive: passo 4, immagine 1 di 1
    • Remove the back cover of the device.
  5. Toshiba Satellite P50W-C Hard Drive Replacement: passo 5, immagine 1 di 1
    • Remove the hard drive from the device by gently pulling on the blue plastic hard drive cover.
  6. Toshiba Satellite P50W-C Hard Drive Replacement: passo 6, immagine 1 di 2 Toshiba Satellite P50W-C Hard Drive Replacement: passo 6, immagine 2 di 2
    • Disconnect the hard drive from the mother board by gently pulling out the black connector.
Conclusione
Altre 2 persone hanno completato questa guida.
USF Tampa, Team S3-G2, Cannon Fall 2017 Membro di USF Tampa, Team S3-G2, Cannon Fall 2017
USFT-CANNON-F17S3G2
4 Membri
7 Guide realizzate
2 Commenti
Can you change the touch panel of toshibasatelliteP50W-B1038.
rizwana rizi - Replica
Hi dear,
My laptop bios was crashed,
I need to radius 15 p50w-c-104 bios dump file.
can you help me please.?
labexperiance@gmail.com
thank you
Mustafa SAYIN - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 704
