Salta al contenuto principale
Toshiba Satellite P50W-C Battery Replacement
Cosa ti serve
  1. Toshiba Satellite P50W-C Battery Replacement, Back Cover: passo 1, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Turn the laptop off, unplug the AC adapter, and any other auxiliary components.
    • Turn over the laptop and proceed to take out the seven 5mm silver JIS #1 head screws. If some of the screws are difficult to take out use the tweezers to help.
  2. Toshiba Satellite P50W-C Battery Replacement: passo 2, immagine 1 di 1
    • Use the screwdriver to take out the three 5mm black JIS #1 head screws that are located on the hinge.
  3. Toshiba Satellite P50W-C Battery Replacement: passo 3, immagine 1 di 2 Toshiba Satellite P50W-C Battery Replacement: passo 3, immagine 2 di 2
    • Use the spudger to pry under the back cover until it pops off.
  4. Toshiba Satellite P50W-C Battery Replacement, Battery: passo 4, immagine 1 di 1
    • Unscrew the four 5 mm JIS #1 head screws holding the battery to the device and gently remove the battery.
  5. Toshiba Satellite P50W-C Battery Replacement: passo 5, immagine 1 di 2 Toshiba Satellite P50W-C Battery Replacement: passo 5, immagine 2 di 2
    • Disconnect the battery from the motherboard by gently pulling out the black connector.
Conclusione
USF Tampa, Team S3-G2, Cannon Fall 2017 Membro di USF Tampa, Team S3-G2, Cannon Fall 2017
USFT-CANNON-F17S3G2
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,019
