Salta al contenuto principale
Toshiba Satellite P205D-S8804 Keyboard Replacement
Cosa ti serve
  1. Toshiba Satellite P205D-S8804 Keyboard Replacement, Keyboard: passo 1, immagine 1 di 1
    • Place the laptop with the screen facing you and grab the opening tool.
    • Insert it into the top corner of the keyboard and slide it to the right along the length of the keyboard.
    • You will feel the popping sensation as it slides along.
  2. Toshiba Satellite P205D-S8804 Keyboard Replacement: passo 2, immagine 1 di 1
    • Lit up the left side of the small plastic bar at the top of the keyboard.
    • Be careful when removing it, because you will need to apply a bit of force .
  3. Toshiba Satellite P205D-S8804 Keyboard Replacement: passo 3, immagine 1 di 1
    • Use a PH0 screwdriver to unscrew the 4 screws at the top of the keyboard.
  4. Toshiba Satellite P205D-S8804 Keyboard Replacement: passo 4, immagine 1 di 1
    • Lift up the keyboard and pull it toward the screen.
    • The keyboard will still be connected to the motherboard by a ribbon cable.
  5. Toshiba Satellite P205D-S8804 Keyboard Replacement: passo 5, immagine 1 di 2 Toshiba Satellite P205D-S8804 Keyboard Replacement: passo 5, immagine 2 di 2
    • To remove the ribbon cable, push upward on the small tabs located on either side of the ribbon.
  6. Toshiba Satellite P205D-S8804 Keyboard Replacement: passo 6, immagine 1 di 1
    • Once the ribbon is released the keyboard can be removed .
Conclusione
Caroline Camp
Membro da: 01/30/17
1 Reputazione
3 Guide realizzate
Baylor, Team 3-2, Whitney Spring 2017 Membro di Baylor, Team 3-2, Whitney Spring 2017
BU-WHITNEY-S17S3G2
4 Membri
4 Guide realizzate
Un commento
rename tool with a standard link for easier accessibility
Andy Feng - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 226
