Salta al contenuto principale
Toshiba Satellite P205-S8811 Keyboard Replacement
Cosa ti serve
  1. Toshiba Satellite P205-S8811 Keyboard Replacement, Battery: passo 1, immagine 1 di 2 Toshiba Satellite P205-S8811 Keyboard Replacement, Battery: passo 1, immagine 2 di 2
    • Flip the laptop over so the bottom is facing upward and the battery is on top.
    • Slide the tab below the battery to the left.
  2. Toshiba Satellite P205-S8811 Keyboard Replacement: passo 2, immagine 1 di 2 Toshiba Satellite P205-S8811 Keyboard Replacement: passo 2, immagine 2 di 2
    • Slide and hold the tab on the right side of the battery to the right.
    • While holding the right tab, slide the battery upward and out its socket.
  3. Toshiba Satellite P205-S8811 Keyboard Replacement, Keyboard: passo 3, immagine 1 di 2 Toshiba Satellite P205-S8811 Keyboard Replacement, Keyboard: passo 3, immagine 2 di 2
    • Place the head of a plastic opening tool underneath the plastic strip lining the top of the keyboard, right above the "PGUP" button.
    • Next, pull the strip up using a plastic opening tool with a light force, until it pops off.
  4. Toshiba Satellite P205-S8811 Keyboard Replacement: passo 4, immagine 1 di 1
    • Lightly lift from the side that was popped up earlier in order to pop the rest of the strip off of the laptop.
  5. Toshiba Satellite P205-S8811 Keyboard Replacement: passo 5, immagine 1 di 2 Toshiba Satellite P205-S8811 Keyboard Replacement: passo 5, immagine 2 di 2
    • Use a #1 Phillips screwdriver to take out the four 4mm Phillips #1 screws that were underneath the plastic strip.
  6. Toshiba Satellite P205-S8811 Keyboard Replacement: passo 6, immagine 1 di 3 Toshiba Satellite P205-S8811 Keyboard Replacement: passo 6, immagine 2 di 3 Toshiba Satellite P205-S8811 Keyboard Replacement: passo 6, immagine 3 di 3
    • Be careful to not lift up on the keyboard too quickly or harshly; there is a ribbon cable connecting the keyboard and the base which may be breakable.
    • Lightly lift up on the keyboard from one of its top corners and pull it towards the screen so you can safely remove the ribbon cable.
    • At the base of the ribbon cable, there is a tiny tab that runs across the width of the connector. Flip it up. You can now pull the ribbon cable free with no resistance towards the monitor.
    • With the cable unplugged, the keyboard can be lifted away from the laptop.
Conclusione
Andrew Meyer
Membro da: 02/03/14
245 Reputazione
2 Guide realizzate
Cal Poly, Team 2-8, Amido Winter 2014 Membro di Cal Poly, Team 2-8, Amido Winter 2014
CPSU-AMIDO-W14S2G8
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 809
