Salta al contenuto principale
Toshiba Satellite M55-S135 RAM Replacement
Cosa ti serve
  1. Toshiba Satellite M55-S135 RAM Replacement, RAM: passo 1, immagine 1 di 1
    • Orient the laptop so that it is closed, faced down and has the battery facing away from you.
    • Use the Phillips 00 screwdriver to remove the 7.50mm screw from the panel.
  2. Toshiba Satellite M55-S135 RAM Replacement: passo 2, immagine 1 di 1
    • Carefully remove the cover to reveal the RAM compartment.
  3. Toshiba Satellite M55-S135 RAM Replacement: passo 3, immagine 1 di 2 Toshiba Satellite M55-S135 RAM Replacement: passo 3, immagine 2 di 2
    • Rotate the laptop 90 degrees clockwise.
    • Pull back the two silver clips that hold the RAM in place.
    • Gently pull the RAM out of the slot and lift up to remove the RAM from the laptop.
Conclusione
Cal Poly, Team 7-11, Maness Winter 2013 Membro di Cal Poly, Team 7-11, Maness Winter 2013
CPSU-MANESS-W13S7G11
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,410
