Salta al contenuto principale
Toshiba Satellite M55-S135 Keyboard Replacement
Cosa ti serve
  1. Toshiba Satellite M55-S135 Keyboard Replacement, Keyboard: passo 1, immagine 1 di 1
    • Start with the laptop open and the keyboard facing you.
    • Tilt the screen away from you to reduce the risk of damaging it as you remove the keyboard.
  2. Toshiba Satellite M55-S135 Keyboard Replacement: passo 2, immagine 1 di 2 Toshiba Satellite M55-S135 Keyboard Replacement: passo 2, immagine 2 di 2
    • Locate the vertical seam between the speakers and the top row of keys on the keyboard.
    • Insert the tip of a nylon spudger into the seam and slowly pry up the panel.
    • Be sure to gently pry the panel to avoid damaging it or the laptop.
  3. Toshiba Satellite M55-S135 Keyboard Replacement: passo 3, immagine 1 di 2 Toshiba Satellite M55-S135 Keyboard Replacement: passo 3, immagine 2 di 2
    • Remove both 6.72mm screws from the upper left and right of the keyboard using the Phillips #00 screwdriver.
  4. Toshiba Satellite M55-S135 Keyboard Replacement: passo 4, immagine 1 di 1
    • Use the nylon spudger to pry up the keyboard. Start with one side and then the other.
    • Be sure to pry gently with the screwdriver to avoid damaging the keyboard and keys.
  5. Toshiba Satellite M55-S135 Keyboard Replacement: passo 5, immagine 1 di 1
    • Gently lift the keyboard to reveal the keyboard cable located near the mouse pad.
    • Disconnect the keyboard cable.
    • Be sure to disconnect the cable before removing the keyboard to avoid damaging it.
Conclusione
klismann Evora
Membro da: 03/12/14
109 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 726
