Salta al contenuto principale
Toshiba Satellite M45 Display Replacement
Cosa ti serve
  1. Toshiba Satellite M45 Display Replacement, Keyboard: passo 1, immagine 1 di 3 Toshiba Satellite M45 Display Replacement, Keyboard: passo 1, immagine 2 di 3 Toshiba Satellite M45 Display Replacement, Keyboard: passo 1, immagine 3 di 3
    • Carefully use the blue iFixit Opening Tool to pry the panel above the keyboard from the left and right side.
    • Push back the screen until it is flat with the laptop.
    • Gently remove the clips that connect the panel to the screen.
  2. Toshiba Satellite M45 Display Replacement: passo 2, immagine 1 di 3 Toshiba Satellite M45 Display Replacement: passo 2, immagine 2 di 3 Toshiba Satellite M45 Display Replacement: passo 2, immagine 3 di 3
    • Use the Phillips #1 screwdriver to remove the two screws.
    • Gently pry the keyboard from the laptop using the blue iFixit opening tool.
    • Slowly lift the keyboard away from the laptop.
    • Remove the ribbon that connects to the laptop.
    • Ensure you remove the keyboard slowly to avoid damaging the ribbon cable.
  3. Toshiba Satellite M45 Display Replacement, Display: passo 3, immagine 1 di 1
    • Remove the 2-3 pieces of black electrical tape covering the black-and-white antenna cable.
    • Close the display, flip the laptop over, and disconnect the black-and-white antenna cables from the Wi-Fi card.
    • Flip the laptop back over and open the display.
  4. Toshiba Satellite M45 Display Replacement: passo 4, immagine 1 di 3 Toshiba Satellite M45 Display Replacement: passo 4, immagine 2 di 3 Toshiba Satellite M45 Display Replacement: passo 4, immagine 3 di 3
    • Remove the two Phillips #1 screws securing the display hinges.
    • It is recommended to keep the screws in a small cup so that you don't lose them.
    • Remove the four Phillips #1 screws on the back of the laptop.
  5. Toshiba Satellite M45 Display Replacement: passo 5, immagine 1 di 1
    • Gently pull up on the display's video connector to remove it.
    • Remove the black-and-white antenna cable from the groove.
    • Your display can now be removed.
Conclusione
Altre 3 persone hanno completato questa guida.
Aryn Pauly
Membro da: 04/29/10
1 Reputazione
2 Guide realizzate
Cal Poly, Team 10-42, Garner Spring 2010 Membro di Cal Poly, Team 10-42, Garner Spring 2010
CPSU-GARNER-S10S10G42
5 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 17
Tutti i Tempi: 8,140
